I'm looking for a a 4L80E converter cover that has the brace mounts. I actually need two of them. They are different from the TH400 because the
The TH400 and I believe 4L60E have offset brace mounts and the 6 bolts start closer toward the bottom.
You can see the mounting ear on the right side is closer to the center and taller. Also, the bottom two mounting bolt holes on each side are very close to the bottom. Like this TH400 cover...
The 4L80E has the brace mounts more spread out, and the bottom two holes start a little higher up, like this black one...
I also need a gear shift indicator for an OD trans, just one.
