The feed limiter valve bore is known for wearing out on 4L80E transmissions. It is a common problem. If your transmission has ever been rebuilt by any shop, or replaced by any remanufactured trans the feed limiter kit has very likely already been installed because it is a common practice by all rebuilders to fix that. Since your transmission is from a truck that is 23 years old, and has a lot of miles on it then it has probably been rebuilt at some time...hard to say. I would stay away from the Trans Go shift kit. It has some cool stuff in it, but some of it sucks like the 3-layer separation plate, and especialy the spring loaded pressure relief deal. If you do remove the valve body you may want to look into some plastic check balls from a company called Sonnax. They have a lot of cool stuff for the 4L80E trans.
