4L80E/harness/controller and TH400/NP205
SoldierFixer
Registered Member
SE of Greeley, CO
I'm looking to sell some trans parts to fund an NV4500 swap into my M1008.
I have a 95 4L80E that came from a 6.5 diesel Chevy 2500. The guy who owned it had it rebuilt, ran it about 3 months, and then the motor blew up. I bought the truck (minus motor) and pulled the trans, converter, and t-case adapter. The truck had been sitting for about a year before I got it. I also have a harness and transmission computer from a 93 Chevy 2500 diesel. I'd like to get $750 for all of it.
Also have a figure-8 NP205 from behind a TH400, with adapter and shifter, and a 2wd TH400 that should bolt up to it. The case is pulled but the TH400 is still in a parts truck, so I'd have to pull it. T-case is from a running truck, trans I'm not sure about- I'd probably throw a rebuild at it before doing anything serious with it. Trans has a 6.2 diesel in front of it. $400/obo for all.
I will consider shipping if the buyer makes all arrangements for truck freight on a pallet. Otherwise, local pickup. I am 45 minutes NE of downtown Denver. I might be able to meet a buyer in Denver depending on my schedule.
Thanks,
Adam
So, to add to the fun, I acquired an NV4500 from a 94 Chevy K3500. It has the wide ratio (super low 1st) gears, which is not what I want. So, it's for sale as well. Includes bellhousing and clutch fork, shift lever, and has been updated to the late-style top plate with bolt on shift tower. $850 or trade for a 96+ (99+ would be better) NV4500.
The 4L80E has a 32 spline output like a TH400, so pretty much anything that attaches to a late 6 bolt 400 is easy. I know a 208 and 241 will bolt up as long as they are 32 spline input. If I recall correctly the 6 bolt 205 is a pretty direct fit and the earlier 205 can be made to work with some effort, although I'm not totally sure on those.
