The trans fuse kept blowing. After much research, I found a quick way to see if it was internal or external was to unplug the the big connection on the driver side. I did and it quit blowing fuses. Telling me it was internal.
I replaced all 4 solenoids and the in trans wiring. That worked, for about a mile. It's all lifted now and I drove it into the garage today. When I went to back it out, fuse blew. Replaced it and through it into drive, blew the fuse. It only blows the fuse when the trans mission builds pressure. When it's low on fluid, it can be put in gear and since it doesn't build pressure it won't blow.
All the solenoids have the recommended ohms. Is it my Tcm? The old solenoids were all the same ohms as the new ones. I don't know what's going on. I'm tired of dropping this pan.
