74kay5
How much is a 4L80E suposed to let into the adapter housing? I'm installing a clocking ring on my 241 and when I removed the T-case ATF came pouring out of the adapter. I removed the 241 once before and that didn't happen, it was pretty dry in there. I have a jack under the adapter housing and ATF seems to be leaking from a weep hole around the input at the back of the transmission. When I jack it up flat it stops leaking? Is everything normal or is a seal leaking?
