Last night my 4L80e lost overdrive with absolutely no warning
. Just cruising along at about 50mph. As I gave it a bit of throttle, I felt it slip and it dropped down to 3rd gear. If I shut the motor off it will "reset" and work for a bit until it slips again, then no overdrive. I dropped the pan this morning and there was some sludge on the pan magnet. I took it to OC Transmissions in Costa Mesa and his scanner confirmed my fears. I need a rebuild.
There goes the $2,000 I was saving for some AFR Heads.
Anybody have anything good or bad to say about OC Transmissions (on Logan - near Fairview and Baker)? I still have my Suburban but plan to drop it off with him this week.
. Just cruising along at about 50mph. As I gave it a bit of throttle, I felt it slip and it dropped down to 3rd gear. If I shut the motor off it will "reset" and work for a bit until it slips again, then no overdrive. I dropped the pan this morning and there was some sludge on the pan magnet. I took it to OC Transmissions in Costa Mesa and his scanner confirmed my fears. I need a rebuild. There goes the $2,000 I was saving for some AFR Heads.
