Ok, bought my 91 3/4 ton burb with 196k on the clock. Now has 213k. Trans always shifted awesome at WOT, felt like it had a good shift kit in it, very firm quick shifts.
Changed the trans fluid/filter around 205k, no issues.
This truck has the 350, so i spend a lot of time at WOT. The truck always shifted really firm, felt great, until last week. Started shifting a little slower, and slipping a little before it softly shifted. Uh oh. Shifted a little slow, but i decided to keep monitoring it. This went on for a couple hundred miles.
Went to tow the boat home, flat ground, highway, and it was obviously slipping. Shifting slow, not able to hold OD, feeling gutless when i got on it hard.
Then it stopped going into OD.
Checked fluid level, may have been a little low, added some. Wasn't low enough to cause damage, not burnt, and no leaks. Hard to tell the level with fresh ish fluid. Has correct amount of fluid now.
Let it cool down, took it for a drive, shifted slow still, but into OD fine.
Any ideas what is causing? I bought this truck for this trans specifically....if it needs a rebuild, i am going to be pissed. To the best of my knowledge, this truck has a recent crate motor in it, and i always figured the trans was recent too, but no idea.
Any vaccuum hookups or wiring things that could cause this? Or does it need to be evaluated by a trans shop? I am cringing right now just thinking about what a rebuild will cost.....definitely close to the value of the truck
Any insight? Scott, do you have any good trans shop reccomendations?
Thanks guys!
Thanks guys!
