Im considering a 4l80e for a truck Im working on that will be used as a dd/work truck/tow rig and Ive been doing some research on wiring and computer controls and ran accross a kit to modify the tranny for use of a vaccum modulator for shifting control.
I am not fond of additional computer controls and wiring so this kit is somewhat appealing and since the tranny will initially be connected to my carbureted motor it is even more appealing to do away with the computer. However I do not want to limit the performance of the transmission so I am not opposed to learning the electronics especially since I plan on an ls swap in the future.
So I would like some opinions on the usage of this kit as opposed to using the electronic controls.
Two things Im concerned with are downshifting and tc lockup. I know that with the 700r4s you could wire up the tc lockup with a switch and control it manually and I assume that you can do the same with this tranny correct?
And as far as downshifting goes, Im guessing that there is no downshift cable available since this tranny was originally meant to be computer controlled so are there any bad effects that may be caused by manual downshifting?
Seems like I have read all of this information here before but cant seem to find it again so any info that you can provide will be apprectiated.
