My 6.5 diesel Banks turbo’ed 1987 V20 Suburban has a 4L80E and 3.73 axles with 315/70 tires. My Compushift transmission control module has a temperature read out. I do not know where the sender is for that temperature. It gets it from the factory 4L80E harness plug.
Living in flat land Texas I see temperatures outside over 100° daily every summer. The 4L80E normally cruises down the highway empty at 70 mph with the torque converter locked at around 170°. Pulling a 10,000 pound trailer in 3rd with the torque converter lock engaged at 60 mph will get the temperature up to 190° or sometimes up to 200°. Never more that a minute or two though.
I thought that was normal and all good. Then I spent 2 weeks driving the truck around the mountains of Colorado last month. I was hitting 200° - 212° on mountain passing going up in 3rd. 185° - 200° going down mountain passes in 2nd. Using the brakes a lot. 200° - 225° on any trail up or down, high or low transfer case. Outside temps were never more than 80°.
Those transmission temperatures just seem awfully high to me. So high that I didn’t do some trails I wanted to accomplish because I was worried about my ability to drive the truck 1200 miles or more back home.
Part of my problem is ignorance. What is the normal operating range of a 4L80E? What is considered hot? I have the transmission lines plumbed first to the radiator and then to the biggest stacked plate cooler I could fit before going back to the transmission. I built it that way thinking it would provide a more steady temperature and not shock the transmission too hot or cold depending on what I was doing and changing outside temperatures. I need to note that anytime the transmission was hot by my standards it never exceeded the engine coolant temperature by more that 5°. I evolved during the trip to higher and higher engine rpm to keep coolant temperature down which seemed to help the transmission temp as well.
Thoughts? Thanks.
Thoughts? Thanks.
