The guy I was trying to help sell his 6.2 diesel stuff is proceeding with his L29 vortec swap. We did a trade of transmissions so I ended up with a Nv4500 and he got the extra 4l80e I ended up with.
His burb had a 208 backing up the stock 700r4 so at minimum it needs a 32 spline input to run behind the 4l80e. A switch on the shifter would handle the 4lo input to the pcm, but the mechanical speedo of the truck will be the issue. We are trying to stay away from changing clusters and the trans is late enough (98) that I bet it's missing the reluctor gear for the rear oss position on the trans since it was out of a 4wd truck.
So in doing some research I found a couple of inline adapters that create a digital output off of the cable. I don't know if this would work because I keep reading about different values for the pulse per mile. What does a stock gm controller need to see? 1000 ppm or 8000ppm
We've talked about going 241 but to stay with the cable speedo we are in the same boat as the 208 his has now. If he went with a electric speedo 241 he'd have to to a 90-91 cluster and drac module which isn't easy to find either.
Any ideas on the adapters? Anybody use one for the vss signal to a 4l80e?
