You can't compare a hydraulic transmission with an electronic one. You can go manual VB in a "non-electronic" tranny and still have line pressure regulated by throttle position. You could set up the oil pump to deliver pressure based on engine rpm, but that's not really what you want. If a tranny get pressure set by the PCM, you have to replace that with something or you will just have full pressure all the time and BANG shifts.Fwiw, having full pressure shifts w/ a manual VB is no big deal. It's just like engine oil pressure, it's proportionate to the amount of throttle given. I drove a manual VB TH400 in my old K10 for years, shifts were soft with light throttle and hard at WOT. Not unpleasant at all.
There is no need for a governer with manual VB since you are choosing the shift points manually. An electronic tranny doesn't need one either, since the PCM already knows vehicle speed and is choosing shift points.
I had to call him 15 times before he finally answered the phone to get the 4L80 back.
