Just did an engine change, bbc to sbc. Left the trans in the truck. Changed ECM and all that. The problem is it shifts hard from 1st to 2nd. Like the line pressure is maxed out. It was fine before the engine change. Changed the TPS to no avail. Is there any other vacuum/electronic gizmo that was on the sbc that controls the transmission 'cause I left all of it on there and hooked up the wires from the bbc wiring harness? Thank you
