4lo gear calculator questions
buffblazer
Fort Collins Colorado
so i posted up my D-max in a different thread and im considering re-gearing since it has 37's on it.
im confused because when im on 4lo this is what i get if i try to enter the tire size as standard and metric.
New Tire Diameter 37
Old Tire Diameter: 30.5
Current Gear Ratio: 3.73
Effective ratio 3.07:1
now if i enter it as metric its a completly different ratio
New Tire Diameter: 356
Old Tire Diameter: 245
Effective ratio: 2.57:1
now a 245/75/16 was stock height and changes to a 30.5 tire.
a 37 inch tire is 356 in metric
so why is my effective ratio different? which one is the true ratio?
Where you are using 245 and 356 as diameter is what is messing you up...on a size 245/75/16 tire 245 is tire width in millimeter not the diameter
in the second one where you input metric you used the wrong numbers, you input the width instead of diameter...so the calculation comes out different
