cybrfire 1 ton status GMOTM Winner Joined Dec 15, 2002 Posts 15,598 Reaction score 2,219 Location Iowa Aug 1, 2013 #1 Looking for the 4wd hump. Bolt in or regular. If not bolt in, needs some extra sheet metal so I can trim to fit.
readymix 3/4 ton status Joined May 30, 2004 Posts 6,704 Reaction score 30 Location Murrieta, California Aug 1, 2013 #2 I have the whole floor I cut out of my truck that I coukd cut a section out of for you. No rust 1987 reg cab K-10.
X xenomarine 1/2 ton status Joined Sep 12, 2009 Posts 1,061 Reaction score 3 Location Southington, CT Aug 1, 2013 #3 The transmission tunnel piece that unbolts from the floor, where the tcase shifter handle passes through?
mrk5 The Sticker Guy Moderator Vendor GMOTM Winner Author Joined Apr 20, 2004 Posts 26,971 Reaction score 27,300 Location Northern Colorado Aug 1, 2013 #4 I can pull the one from the General. It's bolt-in. 1984 K5. Trade you for a set of rear tube doors....
cybrfire 1 ton status GMOTM Winner Joined Dec 15, 2002 Posts 15,598 Reaction score 2,219 Location Iowa Aug 1, 2013 #5 readymix said: I have the whole floor I cut out of my truck that I coukd cut a section out of for you. No rust 1987 reg cab K-10. Click to expand... PM your way. xenomarine said: The transmission tunnel piece that unbolts from the floor, where the tcase shifter handle passes through? Click to expand... Yep, that's the piece mrk5 said: I can pull the one from the General. It's bolt-in. 1984 K5. Trade you for a set of rear tube doors.... Click to expand... You got a 6 door cab now?
mrk5 The Sticker Guy Moderator Vendor GMOTM Winner Author Joined Apr 20, 2004 Posts 26,971 Reaction score 27,300 Location Northern Colorado Aug 1, 2013 #6 Trail spares...
