Alright, over the winter I lost two ujoint caps (closest to transfer case). I swapped in a new ujoint and ever since then I get this vibration/noise when in 4 high. Inside the cab it sounds like loose change, gear grinding. Hubs can be unlocked and the same issue happens. It was brought to my attention I should have a double cardan shaft. If I remove the drive shaft I can run around in 4wd without any issues.
However, I can get this sound/vibration to return under one condition in 2wd. I have to be doing 55 mph+ down a steep grade and coasting.
Ive considered just buying a new double cardan shaft and eliminating that from the equation. The distance between the shaft itself and the ujoint caps u bolt is maybe 1/8" and im thinking any drop in the suspension would cause it to touch. So I feel regardless of the cause of this issue this needs addressed. Agree?
There is no slack in the driveshaft, pinion bearing or transfer case yoke and I cant find any damage on the shaft. I have not been offroading to damage anything.
I have 6" lift, np 205, 2" case drop. here is a video with the sound marked in the video.
at least someone else has heard this before. Ive talked to alot of people for months and noone has a clue.
