Uh Oh.....is a 1973 Blazer full time 4WD and how do I tell if it isn't....and what do I do if it is?
How can I physically tell what it is ...NP203...or what...it has a gear shift on the column and one on the floor....
Drive slugs?
It totally depends on if the transfer case has actually been converted to part time or if the manual hubs were installed without converting the transfer case.
If the case has been converted.
Hi Loc = 4x4 high range
Hi = 2x4 high range
N = Neutral (of little use other than theft deterant or if you have a PTO)
Low = 2x4 Low range
Low Loc = 4x4 Low range
If the transfer case has NOT been converted and you have manual hubs.
With hubs in the locked position
Hi Loc = 4x4 High range with center Differential locked (used on limited traction)
Hi = 4x4 High range with center diff open. (Full time 4x4 for use on high traction surfaces)
N = PTO Output
Low = 4x4 Low range with center diff open for high traction surfaces
Low Loc = 4x4 Low range with center diff locked (for low traction surfaces)
With Hubs in free position
Hi Loc = 2x4 High range (Hard on transfer cases)
Hi = Neutral Truck wont move because center diff has not been disabled
N = PTO Output
Low = Neutral Truck wont move because center diff has not been disabled
Low Loc = 2x4 Low range (hard on transfer case)
Hope that helps. you can run the test I suggested above if you want to see if the transfer case has been converted.
One thing to keep in mind is that when a transfer case is converted you should put the case into Hi Loc every 500 miles or so (no need to actually lock the hubs) Run it for about 10 miles then go back to Hi. This lubricated the rear output shaft. when converted these cases can have lubrication issue if they don't see 4x4 every 500 or so miles.
Cheers,
Rufus
Hi = 2x4 high range
Low = 2x4 Low range
Cheers,
Rufus
I think you need to periodically run a few miles in the loc position to lubricate part of the case.
That's exactly right, actually. Functionally, when you convert the 203 you are changing the way it works from how it was designed and it does not get adequate lubrication while running in 2WD.
On the 203 I FINALLY got out last night, it didn't have a round tag (someone mentioned that in an earlier post), it was a purty rectangle...under about 1" of who knows how old mud but at least the build date matched up to the '74. The PO apparently had some fun with it as I have yet to have this pig moving under it's own power so I can't take the blame for not cleaning it up.
As for heavy? The 203 and TH350 together are just STOOPID heavy. As this was my first experience with the '74 crossmember, more than a few choice words were used and yes, tools did get airborne with sufficient impetus to make them transverse vast distances. I did successfully find most of them again however.
I am NOT a fan of the 8-bolt crossmember. I hope I never have to deal with that again...especially with the engine out as trying to balance the trans and transfer case on a floor jack while monkeying around with that crossmember just sucked. Really, really sucked.
