lobsterpimp
Registered Member
Hey guys,
I've been having trouble with the 4x4 in my recent purchase. She's a 1989 Chevy k1500, 305, with a NP 241 transfer case. When I first purchased it, 4x4 didn't seem to work at all (including no lights on the shifter). After drain and fill on fluids, i did a little checking on it. First I checked to see if the 4x4 drive shaft was turning, and it was. Second I replaced the 4x4 actuator in the front differential and the fluid. Then the other night, I replaced the light bulbs in the shifter. After all that, I jacked the truck up (all four wheels) and put her in 4x4 and I got nothing from the front end. So when I finished, I just put it in 4 HI, and hoped that it might just "fix it's self". Well tonight it did, kinda. When I got in it tonight, I noticed that the 4x4 light was blinking, more off than on. So I left it in 4HI to see what happened. As I was getting ready to turn down my street to go home, it stopped blinking. She locked up like I had slammed on the breaks . I ended up disconnecting the actuator to get it out of traffic.
As it stands now, when I put it in 4x4 (HI or LO) it goes in and the light lights up. But then she won't go. It's like the front end gets locked up close to a full rotation of the wheel. I can go forward a couple feet, then the rear wheels start barking cause the front won't turn. I can back up that same few feet, and then get hung again. I was just wondering if anybody had any ideas about what could be up. I just changed the front differential fluid a few days ago.
I bought this rig for $400. Put a starter, rotors, calipers, pads and 4 new tires on it. My cheap $400 truck jumped to about $1100 fast. Along with the 4x4 probs, I've got what I believe is the beginning of a knock AND a spark knock. I'm too far in to quit now.
Any advice would be greatly appreciated.
