blazin_blazer
can you crunch some #'s and give me specs for a custom cam grind, that will be a lower rpm/torquey motor that will have a ''radical'' cam lope @ idle?
its a stock rebuild, iron intake, rams horn exhaust..compression: my pistons say 8:1 w/76 cc head, 8.8:1 w/64cc's,so taking into account head gasket cc's, less than 8:1, not acceptable...so how much can i have the head surfaced to help bring compression up to 8.5-9to1? or is it to much material to remove to effect the compression much?
I'll just let 4x4 high answer this one . I am at a loss for words.......
