I swapped a junkyard 2003 5.3 into my 71 c20 about 10,000 miles ago and it eventually decided it was done. So I got a goodwrench long block to replace it, just a LM7 like before. I got everything hooked back up today and ran into an issue.
I turned off the fuel pump and cranked it for 30 seconds or so to prime it. Turned the pump back on and fired it up. I let it run for about 2 minutes then shut it down to bleed the clutch, top up fluids and all that. When I went to start it again heard a clunk then it wouldnt spin at all. I got underneath it and there was fuel dripping off the seam of the bellhousing and oil pan, I cant find any fuel leaks anywhere else.
Heres what I have done:
Bench tested starter it spins fine
Pulled plugs and aired out for 2 hours - Cylinder 8 was wet
Tried cranking with plugs out and coils unplugged - no dice
Drained oil to check for fuel in crankcase - looked and smelled like oil that had only ran for 2 min
Any ideas whats going on? Stuck injector on 8 that mess something up?
-it rattled and shook for about 20 seconds,smoothed out for a few seconds,then rattled again,and then locked up tighter than a bulls butt in fly season..
