5.3/sm465/205 swap, need a flywheel
Advanced adapters makes one the lets you use the factory clutch setup
(1979jimmy350) did a write up on this exact swap :waytogo:
Sweet! i'll check it out.
i really dont want to spend 600 for the whole clutch and flywheel setup
i tried to look up the part numbers on their site and nothing comes up
# Advanced Adapter Flywheel Gen-3 Vortec Part # 711500M
# Advanced Adapters Pilot Bushing Spacer Part # 716155
You mat have to call to order not sure havn't ordered on for my project yet either want to do 6.0/465/205 so post up any probs with it.
:popcorn:
Well ive been checking around, and apparently you can buy an ls1 flywheel and an ls2 pilot bearing to make it work and its wayy cheaper
I haven't seen it first-hand but the Ram flywheel #1550 is drilled for both old school and gen 3 clutches. I emailed their tech support and they confirmed it.
This is what my shopping list looks like.
Ram flywheel #1550
Luk 04-049 clutch kit, pressure plate, bearing, pilot bearing(can’t use), clutch
LS2 pilot bearing GM 12557583
Flywheel bolts GM 12563533
0.400 Spacer GM 12563532
Maybe it'll help.
