5.3 swap help!
beto101
Phoenix Arizona
Ok finally getting to doing my 5.3 swap into my 80 K5. I have one issue so far and that's the driver side manifold is inside the chassis. Anyone know if they make headers for the K-series trucks with LS swap? Any other ideas besides torching away the chassis?
What is the original application for the exhaust manifolds? Some guys say the LS1 F-body manifolds work better. Doug Thorley makes LSX headers for trucks, but they aren't cheap.
5.3 swap help
Engine is out of 03 yukon. I've tried looking for the f body manifolds and no luck in my are
I have one more question. If I change the maniflods to the F-body manifolds will my stock "Y" pipe from thr donor vehicle?
F body manifolds seem to be the fix for this with the research I have done. Even then it is a tight fit between the frame rails.
