You'll need a flexplate and spacer for a 6.0l w/4l80e. Part number for the spacer is 12563532, flexplate part number:12551367. Longer bolts are required part number:12563533 (qty 6).
It's not a real good idea just to space the 4l60e dished flexplate because the starter will be engaging on .400" less teeth and neither the starter nor the ring gear will last if it ever starts at all. The 4l80e flex plate is flat and is designed to be spaced .400" and still allow proper starter operation.
