5.3 swap w 6L80E, which transfer case.
75K5
Michigan
I bought a 2009 tahoe 2wd police package that was wrecked and I've pulled out all of the powertrain componets for a swap (engine, trans, fuel tank, fuel system, etcs, etc). The tahoe had 900 miles on it when wrecked, so it's practically brand new. Before I can start getting a handle on this, there are two things I need help with:
1. Which transfer case(s) can I use. I would prefer a push-button shift instead of a shift lever. This is going into a 75 K5 that currently has 4WD.
2. Can someone send me a link to the motor mount adapter plates?
Thanks for the help!
Brian
by the way, I have a 27 spline output shaft. Trans code is 9CED
OK one more post. I thought it had the 6L80E but after looking at it and comparing to pics online and output spline options, it doesn't look like a 6L80e. Maybe it's a 4L60? The code on the trans is 9CED.
Brian
