for a simple fuel set up here is the common set up
(1) 98-2002 ish corvette fuel filter/ regulator at napa is 45.00
(1) 3/8 Fuel line repair kit from napa, part is 15.00
(1) fuel pump that can support 60-65 psi, I used the holly, summit sells for 110.00
(3) 3/8 to an fuel line adapter. summit has em for about 16.00 each
(1) 5/16 to an #6 fuel line adapter, summit, 16.00 each
the corvette fuel filter/regulator mounts after your fuel pump and regulates the flow to the fuel rails. This set up allows you to only run one line to your motor.
for the fuel line I use push lock hose and push lock #6 an fittings. The line will cost about 2.50-4.50 a foot. The straight az #6 push lock fittings are 4.50 and the 90 degree ones are around 12.00-15.00 you can obviously use steel braided rather than the push lock hose and fittings.
just noticed your local
loppers is where I bought the fuel fittings and adapters along with the fuel pump. If your in mesa sometime you can look at my buggy as it has a blazer frame under it and you can see how and what you need to do.
