4xcrazy
3/4 ton status
This is the first 5.3 I have ever had. It's really kind of been a pain too, anyways, I just replaced the alternator due to fluttering lights and bouncing volt gauge, thinking maybe the first morning start up squeak was possibly coming from the bearings as well because there is a dusty debris around that area and on the bracket...
Anyways... the squeak is still present. I have already replaced the tensioner pulley, removed, cleaned and checked the idler pulley, even removed the belt completely and started it to ensure it was in fact a belt driven squeak. It is... the noise was not there with the belt off.
I cannot positively pinpoint where this noise is coming from even with the stethoscope. It's not the AC belt or its tensioner either. Not a power steering as the sound is not that low and to the right.
It almost sounds like it's dead center, like a water pump.
I have never, in my 23 years of working on engines, ever heard a water pump squeak. Have I just been neglected in this phenomenon? I have only ever had to replace them when they start leaking or flat out break.
Anybody know or heard about this new design style of pump squeaking?
It only does it when it's dead cold, mostly in the morning after sitting all night and will only last about 3-4 minutes or as I would think whatever is squeaking, warms up and stops. Won't do it throughout the day though at all.
