Ok, so our 2001 tahoe, I do a full tuneup (Plugs, wire, fuel filter), injector cleaner added to tank, sea foam ran though vac line, cleaned out throttle butterfly. No issues, Ran like a champ during test drive, and the day after.
2 days later.....started stalling out in chain controls going up the mtn with my parents driving.
Towed off of summit in full chain controls (2:30am = happy parents
), dumped in the driveway at our tahoe place.
Went to trouble shoot the next day.
Started up the next day, would start every time, but wouldn't' run above idle, and not smoothly at idle. Would stall out in gear.
Added some 2 bottles of HEET to almost empty tank to eliminate possible water in the gas. Pump didn't sound right priming.
Bought a scanner and fuel pressure gauge to verify my hunch that it was a fuel pump (hoping it was some bad sensor). General misfire code, lean bank 1, lean bank 2, and 10-30psi of fuel. I was right
150k, oh well. Got teh fuel pump/filter replaced.
That tuneup we did was the first major service service besides trans fluid a time or 2. Oil changed regularly, but at walmart.
Now for the kicker: It runs rough, stumbles off of idle, and throws a check engine light.
Code is misfire on cyl 2.
First, How does it know what cylinder is misfiring?
Second, in my head, cyl 2 has the following things that could go wrong.
Air - its got to be getting air, or the rest of the cylinders wouldnt' work.
Plug - need to inspect
Wire - resistance must be tested, but "new".
Coil - resistance must be tested per service manual
Injector - must be cleaned somehow?
Am i on the right track for this? Anything simple i'm missing.
My parents are getting frustrated, and we (myself included), are regretting touching the thing at all. If its not broke, don't fix it....right?
), dumped in the driveway at our tahoe place.Went to trouble shoot the next day.
Sweet
