5.5" lift blocks, and ubolts to install them. and more
shady
1 ton status
iowa
ordered for a 72 blazer but should fit any of our chevy's I believe.
I have 5.5" lift blocks (4" lift +1.5" anti sag), the u bolts to install them. plus I also have a full set of front u bolts, brake line extension brackets, and spring eye bolts.
it was a tuff country 4" EZ ride kit that I ended up just using the front springs. Oops:rolleyes: I forgot about the ubolts and bought new ones:doah:, then changed my mind and did a shackle flip.
so here it all is for $50 plus ride.
How long are the rear u-bolts?
Interested in the whole thing depending on the length of the rear u-bolts.
Also, everything should fit in a large Flat Rate box, correct?
they might fit one of those boxes, I don't know how big they are...? I'll have to check. The rears are 14.5" overall, 14" inside,
Ok, let me measure the spring pack on my M1008. Unless someone already knows how thick they are?
M1008 rear springs are about 3.5" thick and the U-bolts are 10" overall length or about 9 and 3/8" actual length because they are 5/8" diameter.
M1028's and M1031's are about 5.5" thick and use 11" actual length or 11 and 5/8" overall length.
