DavidB
MY K5 has a TBI 350...what would I have to do to use that TBI setup on my K30's 454?
The 350 one is the same cfm as the 454, and the same size injectors.
I heard once of someone running a dual-TBI setup successfully, but it involved a LOT of work and in the end there was no benefit or cost-savings. It was more of an experiment than a useful project. I'd sell off the parts you don't need and put the money toward a Holley Projection setup.blasphemous said:This may be way off base, be gentle with my ignorance![]()
What would the possibility be of using two SBC TBI setups on a "dual quad" style intake? Use one set of sensors and wiring, but run a seperate ECM for each unit. "Y" off the wires for the sensors to feed each ECM.
I know it'd be kind of a hack setup, but it could be done on a very inexpensive budget. Also, if it works, it could supply a healthy BBC easily. Probably have to run two stock pumps or get a good upgraded one. That should round out the fuel end of it.
K10A'sBROinSLO said:OK...so just the TB?
