5 Blade Fan
toddball
Registered Member
CO Springs
My radiator fan broke, took out water pump too. It's part no. 14077928. Where do you find a replacement?
19" standard rotation w/ ac and fan clutch.
Used is probably your best bet. Post up in the Wanted forum, I’m sure someone will have one they’d sell.
Ok, is there an upgraded version to try? 7 blade? It worked pretty good for stock with heavy duty fan clutch. Also what year range has the same as mine, 1985?
7 blade would be an excellent upgrade. Any year as long as it’s a standard rotation set up like yours. The last few years of square bodies had a mix of standard and reverse rotation so be careful.
Derale makes a 6 blade for fan clutch. 17119 is the part number. AZ truck upgrade to extreme duty fan clutch while your at it.
Thanks. I'll look into that. Yeah, I meant I have a severe duty one, forgot there are three levels of fan clutch.
