IN (5) Brand New 15x8 8x6.5 Steel Wheels & Rock Rings
truck-oholic
Monrovia, IN
Long story short, right after building these I realized I'd be better off staying 6 lug on my one rig instead of converting over to 8 lug as originally planned. Trust me, you can't build these for cheaper, this is literally material only and I shopped around extensively to get the cost down this low. Wheels are Bart Wheels with 3.5" backspacing and 5.125" center hole. Rings are 1/4", fully welded. Wheels will come with new heavy duty valve stems not installed yet. The rings received several coats of weld through primer and Steel-It type paint before welding. All that's left to do is a little paint touchup and/or color change.
$750 picked up.
Located in Monrovia, IN 46157.
Thanks,
Jesse
610 999 1546
