$5 each and shipping! or free + shipping New parts and pics added
desertrat67
Hawk Driver
Dumfries, VA
Updating after having sold or found out some stuff was actually no good.
OK, I have:
a 4wd sterring box
a set of 4.10 gears for a D60. truck had 98K I believe.
Stock D60 steering arm.
oil cooler from my 88 V30, 454tbi. worked when I pulled it off the truck a few years ago.
Tail shaft for 241 pass drop(came from my 90 Sub when I SYE'd it)
10 bolt spring plates.
2 front 3/4 ton brake calipers. Probably only good for cores. I have never used them(came with truck when I bought it) These are free with shipping.
14 bolt stock pinion(1350) sold
14 bolt spring plates. These were the ORD u-bolt flip kit parts. I needed new u-bolts with new truck and just bought another kit. sold
power steering pump and reservior from 88 TBI 454. sold
As the title says, $5 each and shipping to your door. I jsut want to clear up some space and get rid of some weight before I move in a few months.
4.56 gears for the 14FF.
14FF open carrier.
$10 for both of these?
If so, then sold. Let me know the shipping to 67439.
The drag link is attached to the double tie rod that points front to back? I may need these, how's the steer box? Miles? Thx, Andrew
That is the drag link. It is atatched to the pitman arm(connects to sector shaft on steering box). The box was on the Sub when I got it with 72K on it. It is an o-ring style from my 90 Sub.
Getting shipping prices and trying to configure a box for the carrier and gears for Wes right now. If he decides not to get them, Dave is next and then Rob.
Got your PM. They're sold. I will get you paid tomorrow evening.
This is a factory cooler. It mounted on the left side of the grill(drivers) and the lines ran back to the oil filter adapter. About 8" wide by 12-15" tall. I can get better measurements and pictures tomorrow.
14bolt spring plates
I'll take the 14 bolt spring plates if they are still available.
Lane
Gawdammit! I just checked Pay Pal to see if you received the payment several days ago and nothing. At least PP isn't even showing me a transaction ever been made by me. I've had problems with PP before and it seems to be happening again. Let someone else have the parts I was requesting. I'm not gonna hassle with PP again. Those fuuckers.
OK Wes. I was going to pm you again today to see if you had jsut been busy or what? You heard him guys, parts are available again. Dave you will have a pm here shortly.
