5" lift steering arm or pittman arm
timpact14
Registered Member
arizona
running all 5" lift alcan springs...i've heard a pittman arm wont work well with lift over 4"...will the raised steering arm be ok instead? any suggestions..
you need both. if you pay the 25dollars to be a supporting member, you can then use the search feature, and you would have known the answer to this question 3hours ago, when you first asked it.
get the 4" raised steering arm. the only pitman arm I have seen is a 2" correction. that may have a negative effect. start with the 4" and see where you need to go from there.
crossover would be best. it's more money the the band-aids you suggested but if you have alcans all the way around you either have the money or you bought them used.
