(5) StazWorks Double Beadlocks
mtnman210
Northridge, Ca
I have 5 StazWorks Beadlocks with all the hardware and the inserts. One may be missing the rubber o-ring but I'll double check(nothing a bead of silicone won't fix) they all were mounted and held air with no leaks. they have some surface rust but it should easily be removed with a wire wheel.(hell if you want them I'll wire brush them and throw on some paint.)
they are 16.5x10, with 4 1/2" backspacing and fit chevy 8lug pattern.
Locate in San Fernando Valley, Southern California
I would rather not ship based on weight alone.
asking $1000 for all 5
outter ring with custom bowties
inner wheel
all hardware
inserts
