bayou blazer
This is the last item to go for my project. I have a Gen 6 502 engine that is complete from carb to oil pan and has a Powermaster starter as well. THe engine has been started to ensure oeration but has no real time on it. It should put out over 500hp and 580-600 ft-lbs of torque. More than enough to turn the tires.The specs on the engine are as follows:
Gen 6 block with 4 bolt mains and standard bore.
GM forged crankshaft
high performance rods with 7/16 bolts
forged pistons
ZZ502 roller camshaft wth Comp cams pro magnum roller rockers.
ported "781" casting heads with hardened exhaust seats and 3 angle valve job
Edelbrock RPM Performer intake that has been port matched to heads.
795 cfm Q-jet that has been jetted to support this engine
Powermaster high torque starter.
Engine comes with flywheel and water pump and alternator and power steering pump and brackets.
If needed I will throw in a set of 2 1/8" primary size headers that were built for the engine to fit in my GMC Jimmy.
Asking $4200
This will need to be picked up or delivery arranged. If anyone has question feel sree to ask and I will try to get back to you ASAP.
thanks.
forged pistons
Asking $4200
thanks.
