52" 1/2 ton springs on a 1 ton front??
shady
1 ton status
iowa
I now have a free leftover set of decent 52" springs from my burb. Can these be used on the front of my 1 ton CC as a B52 setup? If so then all I need is an ORD shackle flip for the rear and I'll have my lift. I do have the old fronts also, so I could add a leaf or 2 if need be. I plan on setting the truck up for as much flex as I can get, and it will be shortened later like ORD's CC. Thanks for any info.
Yes its an 88 with the 454tbi
I have 52s under my fairly heavy rig with a BBC. I have added/removed/played with the amount of leaves though till I got it the way I like it.
