SCOOBYDANNN
yellowK20 said:Do you foresee any issues with your front pinion angle?
it was the same, if not worse, than with the 6" lift. so no
:hawkeye649 said:That looks like you'll get a few inches of compression before it hits your frame and stops....
clarkjw24 said:The spring eye will rest on the frame but the spring pack continues to compress with 52s and 56s. My 56s work great but now I've got to put bumpstops and limiting straps to keep them in check. Super flexy.
hawkeye649 said:Doesn't really sound ideal. Sounds like a lot of stress on the bolts holding your springs/shackles, and on the frame. I would think a bump stop would be a must to stop negative arch as well, I hear that's bad...
how do you think they compare to ferd 57's up front? http://coloradok5.com/forums/showthread.php?t=138587&highlight=63%27s+swap+springmuddybuddy said:lets see pics of the the 56's in actionhow do you think they compare to ferd 57's up front? http://coloradok5.com/forums/showthread.php?t=138587&highlight=63%27s+swap+spring
that thread has crazy flex with ferd 57s. would you say the 56's are as flexable?
I built some clamps so that my springs dont do that. That is definately NOT good for the main leaf. I don't know, i think i would have more fun limiting the flex and making it through the trail than flexing it like mad and replacing the main leaf 3 times before the end of the trail
. Its going over the tank, when I do the full cage this winter. maybe a flip down style stinger. I'm thinking one that will put the 42 just a few inches from the ground when down and will hug the gas tank when up.
