WJACKSON11X
Anybody had problems with the caster angle after doing 52 swap? I have mine in the forward most position with the rear hangers moved, 7.5" shackles and a zero rate. Just curious if anyone has had any problems with the front pinion and DW. In the process of doing crossover on my 10 bolt, so havent been able to test drive it yet. Anybody having to use pinion shims?
