52's in Front and Steering
nvrenuf
Holy crap, it's running!
Mobile, Al.
How far is enough / too much?
I know the 52's will push the axle 2" forward, is it worth it do go for another inch with a Zero Rate?
How does the push forward effect crossover steering? How far can you go and retain a front mounted drag link?
I moved an extra inch foreward, no negative effects with my cross over. I did have to lose my inner fenders and slightly trim the core support. Instead of a zero rate, I drilled another hole in the spring pad and in the spring plate to gain the extra inch. .
Thanks Thor!
I see you run foty-toos :D , how much lift?
About 5". It sat level with 6" tc ezrides. Front is a little lower with the 52's. Going to pull a leaf or 2 in the rear to bring it down when I get my ladder bar made.
I moved my axle forward 4.5". The pitman arm's TRE sits right between the U-bolts on the spring plate. There's also a heck of an angle between the pitman arm and the steering arm on the opposite side.
