i need some help making a decision here. and i will start a build on my blazer in a bit, but heres what i have......im removing the 6" skyjacker lift i installed back in high school about 17-18 years ago. i finally acquired a 14bff/d60 4.10s to replace the sorry d44/12b 3.42s. i want to improve ride quality, flex. etc.... i dont go extreme rock crawling, but do take the family out to the mountains every now and then and have some fun, has to clear the 37s on H1 beadlocks as well. i want it to be an all around capable rig. it never sees speeds above 60mph.
for the rear, i have already removed the 12 bolt and spring hangers, plan is to get 4" shackle flip with zero rates and 56" springs....... for front, i wanted to see if anyone had a preference for either tuff country 4" EZs or 52 swap? are there any advantages with one over the other? it may cost the same to do either,..... im gonna do crossover steering too. i looked at the DIY4X 52 kit with body mount bracket. not sure which way to go, seems like theres pros and cons of 52 swap, but i dont have any experience with it. thanks.
