52's question
BLZN4FN
Englewood Colorado
sorry have to ask what spring bushing did you all use on your 52"s swap? I'm also going to run diy's ft spring hanger kit.
I used stock bushings for simplicity later on. I'm using B52's up front and Kert's 7.25 shackles in the rear. I had Kert weld some spacers on the lower end of the shackle so they'd work on the standard bushing.
I would strongly recommend NOT to use stock rubber bushings, if you will convert to crossover steering (which you should).
I did, and the steering sucks:doah:
Poly-bushing has much better side-stability
