56''-2'' lift leafs?
BILTIT
Lloydminster,SK
Anybody know were to get some 56'' leafs with 2'' lift?
Running 6'' Tuff Country in front/shackle flip and zero rate in rear. Looking to add 2 inches and need to replace the rear springs anyways.
Going to use a zero rate and longer shackles in the front.
i looked most comon places. no luck. only 52" leafs.
i think denver spring or alcan spring will be it. thay are custom made spring packs.
56" springs come in a lot of pack configurations and rates. Adding a few more leaves to the pack might just work.
I think Skyjacker used to make them but I can't find them now. I neded some also but ended up using stock 8 leaf packs instead. The may not compress a whole lot but I imagine they'll droop pretty good.
Edit: I priced some Alcans about 5 years ago and they were in the $600 range for the set (+ shipping).
Ya, skyjacker sells them, through summit they are 600 for a set.
I think i will try locally or just add some leafs.
I put some Rough Country 2" aal's (short style) in the stock 56's on my old crew cab and they broke within a couple of months. RC warrantied them and the second set broke also. I eventually removed them and went with a taller block.
I have 2'' blocks but not sure how safe it is to use them with zero rates?
ive been running 2" blocks with a zero rate for about 3 years now, all good in the hood... the zero rate is bolted through the spring so its not like your stacking blocks, but there is the added wrap leverage which makes this set up equal to a single 3" block
