OK,
Got some solid information.
AAA spring out of SLC can get the 56 inch springs that have the 26/30 offset. They’re $300 per spring.
Now, that won’t necessarily solve my issue. As when mounted to an Abomb front winch mount that’s only gaining 2 inches of forward movement of the axle.
I need close to 4 inches.
The nice people there explained to me the cheapest (and, probably the best way. For me anyway) way to do this.
Bring down the mainspring of what I’m using now (which is 5 leaf set of 52 inch springs from the rear of a Chevrolet K10)
They instructed me to bring them the main spring from one of the 5 leaf, 52 inch springs I’m using. They can duplicate that, without drilling the center pin hole. Then I can use my existing loose leafs to build whatever I need. Cutting off excess lengths, if needed. To get the center pin where I want it, and get the number of leaves I want.
He said they will charge me $120 to make that custom main leaf, no hole, no bushings. Two custom main leaves will be $240.
It’s either that or go coils. Which is an entire different story.
They also said, I could order just 26/30 main spring, and build from there. Hmmmmmm…
