krazykawika
Registered Member
whats the diffrence between putting a 52" spring or 56" on?
). My math says that my 4 leaf 56" springs are about 250lb/in. My stock fronts are something like 375lb/in, so I think I'll add a leaf to the 56" springs to stiffen them up to about 300lb/in. Then I am going to try and find some 60" springs with a spring rate around 200lb/in for the rear.I guess what I want to hear is from someone who has the 56's up front, and what they have done to their spring packs, and how they work.
That question is subjective. It really depends on how soft you can stand the front to be. My 56"ers on front & back have 5 leaves & are very soft. One set is from the rear of a 1/2 ton truck. The other set I took leaves out to make it match the 1/2 ton set.
you guys are talking about removings leaves to make it softer. do you want the back and front the same or the back harder or softer than the front? it sounds like most of you with the 56" are running with 5 leaves is that all around?
