i knew you'd reply... my prior argument still stands, it's not a misconception... it's simple physics..
you may not be having an issue, but generally over the decades, a longer spring has been shown to have way more tendency to wrap.. how much hp are you running?
Weak motor, rock crawling with 40s though. HP wouldn't be relevant here, torque would. I would notice if there were wrap issues, I've spent a lot of time monitoring it because I can't afford driveline yokes.
It's funny you reference physics. I am a materials engineer with an emphasis in metallurgy and mechanical, and there's automotive engineers that agree with me. Not to mention I've done this whole thing once or twice just like you
We should agree to disagree here, but if you drag physics in to this, I will keep setting the record straight for the sake of the correct use of physics being displayed here.
Point is for the OP, if you decide to run 64"s, you're going to have axle wrap issues if you don't get a leaf pack for a heavier vehicle. Still flexes well, just don't make the mistake of grabbing a light duty pack and ending up with bad wrap issues. And ryoken, it is a misconception that 64"s will have bad wrap issues. They don't
have to. A guy could run more leaves and not have that issue, like I've explained. My '96 that I've plowed with for the last 15 years doesn't have any axle wrap issues, even with an 800 lb plow and 1000lbs of gravel in the bed. 64"s are so flat that it's not going to noticeably impact the vertical travel.
