robert97dodge
I have a '86 K20 that I am wanting to put 56" springs up front when I do my rockwell swap which should be real soon. I was wandering a couple things. First do you measure stragiht across from bolt hole to bolt hole on the springs to determine how long they are? Also what kind of newer vehicle do these springs come in? Like if I wanted to order a new set for about 4" of lift what vehicle do I order them for? I am wanting to run them with the short end forward to move the axle forward too. Right now I have 6" springs and 3" body lift and 38.5" boggers and the tires rub. I am about to be stepping up to atleast a 44" and eventually a 49" so I know that I wont be able to use stock leaf but I do want to keep it really low and I will cut as much fender as needed pretty much.
