perp
one before pic too
Rear taper
Set up guide lines for fab with block string and shelf brackets
removed inner fenders and narrowed them to about 8" IIRC (removed about 4") cut the body along the lines (chalk line) and cut a relief at the bottom rear of door opening. the relief was an educated guess and i will have to do a little filling in, no biggie. rotated the bed side in and welded it in. If you are interested I can take pictures of the underside. made sure it was straight and welded it solid along with welding in the inner fenders. they really stiffened up the sides alot. and i did have to set the narrowed fenders on top of the bed floor and trace trim the floor so they fit in the holes. i am in a hurry so if i left any questions or you want other pics let me know
Rear taper
