Black Betty's Daddy
Registered Member
So I know alot of you guys have 56" leafs on the front of your chevys and what I am wondering is how many leafs are in your pack? I have a 85 k5 with 10bolt front(eventually d60) that has 4" lift springs on it now. I have a set of late 70's 2wd 3/4 ton rear 56" leafs that I am going to put up front on my k5 with some DIY4X b52's and hd 7" shackles and custom shock hoop with ext. brake lines plan on using rs5036 or rs999036 longest shocks I can find for reasonable price. My rig is not some high dollar rock crawler but the club I run with MIOBI.org there wheeling grounds have alot of different terrain off camber crevices cracks hill climbs creeks lots of rutted trails through the woods and hilly terrain! I've noticed that the rigs with alot of flex do pretty good on the more technical stuff down there. My goal is to get as much flex out of my leafs as possible the 56" leafs I have now are stock 7leafs in the pack with overload with the retaining clamps around the middle of the spring. Looking for your opinions on leaving them the way they are , just removing overloads, taking out every other leaf? What have you done, hows your flex, ride quality,axle wrap problems, would you change things now that you've had them on and wheeled them a while? Thanks guys and hope to hear your thoughts and opinions!
By the way I will be running 63"s on the rear with a shackle flip and inboarded shock mounts
