There's no need to move the shackle mount.
But you'll probably need a longer shackle.
Remove the leaf from the shackle in the rear.
Measure your spring along the arc, then measure that length in a straight line from the front spring mount.
swing the shackle backward until it intersects with the measurement.
Then see if it's enough frame clearance for the spring-eye.
If it's not, you need a longar shackle.
This way you can easily measure how long shackles you need as well.
I don't know how much more to the front, the front mount is moved with your B52:s, but when I moved my front mounts 4", I think I needed about 7,5" shackles.
But I ended up making them 8.25", so I could tie them together for increased side-stability.
This is how my shackle-angle looks like at ride-height
And assuming your doing a crossover conversion as well,
make sure you use poly-bushings in your leafs, otherwise it will wander alot side-ways on the road.
