Foo. 56" in the front could be too flexy, and will take some fun to mount. 52"s are exciting enough.
That said, 56"s come on the rear of some 3/4-tons (Burbs, pickups) and most all 1-tons, in packs with varying numbers of leaves.
My C20 crewcab (call it a light duty 1-ton) had like 8-leaf packs, which I whittled down to six, I think, for the rear of my K5, and then used its original rear 52"s for the front.
56's mount in the front the exact same way 52's do, Either flip the hanger forward, or B52. The difference? you don't need to move the stock shackle hanger for awesome shackle angle!
I'm interested in front 56" springs as well after recently completing a rear 56" swap. Massive down travel and the 3/4 or 1 ton springs can carry a bit of weight which helps with a BBC.
