56's vs 52's out back...
for me it was the other way around, my old 52's were very clean and had new bushings in them, my 56's are old greasy things with cracked bushings that need replacing, know I can safely say that I have gained alot more flex compared to the 52's, my pack that I got was very soft and I left 7 springs in them and they almost sit flat with the weight of the truck on them, other packs may not be as soft so that may be why some are saying not much of a gain. If I were to take out a few more leafs and add a zero rate to get my lift back I bet they would flex even better but then I run out of shock :)
sweetk30 said:
these are pics of the 64" 88-up spring swap. and there is a pic of the frt hanger and rear flip kit hanger 4" ord part and side shoot of rear setup with 2" block to level out truck. and a shot threw the gas door at were the frt hanger center line is about . the springs are 1 ton 5 leaf and are 88-up style.
FYI your rear shackle angle is horrible
